avantbored
Hi all.
Picked up some gear from a local guy who's unloading some unused kit. He's very careful with his components and tends to only buy from other enthusiasts and audiophiles. When gear isn't working functioning, he usually sends it to a reputed shop in my area (Los Angeles).
This is just some anecdotal context to say the issues with the component in the title aren't from a flipper or heir who's out of their depth with audio gear.
The kit I picked up:
Denon HA-500
Denon DL301 MK1
Yamaha M4 (unexpected! been on my list of to-one-day-own amps)
Chief complaint: Denon HA-500 MC Cartridge Amplifier presents channel imbalance (left louder than right) and hum on both channels.
I have this hooked up to the MM of my Nakamichi CA7A (NB: Some of you may be thinking, "Why do you want to hook up a MC head amp to a preamp with a built-in MC stage, and a flexible and very good one at that?" We all get curious!), and the head amp hum hum hums while the left channel sounds fine and the right channel is weak. Some scratchiness while operating the knob (stepped, just to turn it on and off).
I opened up the head amp and didn't see anything, though some caps did wiggle.
Any ideas?
Specs of both the preamps:
Denon HA-500
■ Head amplifier for MC type cartridge
■ Input impedance 100Ω
■ Gain 0dB (PASS), 24dB, 32dB switching
■ Output level 2.5V
■ Frequency band 10-600,000Hz + 0dB -1dB (24dB) 10-600,000Hz + 0dB -3dB (32dB)
■ Total harmonic distortion 0.008% (0.3V output 20-20,000Hz)
■ Intermodulation distortion 0.008% (0.3V output)
■ Input conversion noise -157dB (RMS, RIAA + IHF-A, input (Short)
■ Channel separation 70dB
■ Power consumption 14W
■ Power supply AC120V 50 / 60Hz
■ Weight 2.2kg
■ Dimensions W12.6 × H7.1 × D30.5cm
■ Release September 1978
■ End of sale 1985
Nakamichi CA7A
Frequency response: 1Hz to 100kHz
Total harmonic distortion: 0.002%
Input sensitivity: 0.16mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 84dB (MC), 88dB (MM), 94dB (line)
Output: 150mV (line), 2V (Pre out), 7V (Pre out Max)
Dimensions: 435 x 82 x 310mm
Weight: 7.2kg
Denon HA-500
Denon DL301 MK1
Any ideas?
Denon HA-500
■ Output level 2.5V
■ Weight 2.2kg
■ End of sale 1985
Nakamichi CA7A
Weight: 7.2kg
