I got this great amp in after an extensive repair/refurb. The refurb was valid only the amp returned with the complaint "blown fuses". Indeed, the fuses in the line for the power output (2x 6.3AT) had failed. Could not find anything amiss but upon returning the amp the fuses were found to be blown again. Egg on face ensued. New fuses were installed. Again the amp worked flawlessly until my house circuit breaker (16 A) tripped. The coin dropped. The big toroid has a massive inrush current and the new reservoir caps C47/48 (which were replaced by Kemet 33 mF/75 V units) presented a dead short on top of that at poweron. So I delved into my tray and found a P13 inrush current limiter aka NTC of 10 ohm. After installing it the inrush current was 15 A (vert: 5 A/div, hor: 5 ms/div):
Still substantial but not enough to blow any fuses. The NTC is mounted on the mounting strip next to the power cord entry:
The NTC nibbles off a tiny bit of headroom. As it heats up this becomes even less. Full power is 2x 172 W into 8R.
Now I am still not sure that this solves the issue. But I can't think of anything else. Any ideas?
