Thanks for the help, just now fixed a Denon PMA-2000R!
It was pretty simple to get the input selector switch out, which has its own little PCB.
Just take the case cover off.
Take out 8 screws holding the front panel on.
Also the ground strap screw.
Remove the Input selector switch's knob and retaining nut.
Tilt the front panel down and carfully reach in and pop the ISS board out from the 4 plastic hold downs.
Then you can undo the single wire harness going to it. Did not have to tilt amp to the side.
There was no extra metal bracket on the switch so no soldering required.
Although if you could remove the LEDs it would be way, waaay easier to get the metal pins that need to be
squeezed together, to slide out of the brown board the switch sits on! Just on the one side though, small needle nose fit just fine for the other side.
It seemed as though there was a residue of oil, maybe dialectric grease, coating parts of the switch? I simple wiped everything down with Iso-
alcohol, put back together, problem solved
