We are still receiving entries now, it is not ended yet. The winner will be announced on Friday 5/26 here.So who won?
That's a nice looking straw! FYI we have DeoxIT in needle dispenser bottle too :Me of course, and I haven't even entered yet!
'Bout time yall came up with a bendy straw. Still like mine better though. I've got a few "custom" made that fit into the strangest of locations and put the spray exactly where needed ...
... and ... can't stress this enough. Be CAREFUL where you spray the stuff as it can craze plastic - not good when we're talking face plates or meters. It can get into the tiniest holes too, so DO mask carefully if there's ANY doubt. I always spray on the low setting ...
Another neat trick ... spray some in a needle bottle for really tight locations.
For product information:
http://store.caig.com/s.nl/it.A/id.1703/.f
We have the 5% in needle dispenser too, which is the same 5% solution like D5 spray if you spray the solution out in a cup:Not in the D5, eh ... or at least not that I've found. I've got a bottle of D100, but that's a bit overkill for most of my projects.
PS ... I hope your NEW! IMPROVED? fold down straw works better than the ones they stuck on WD40 ... those are seriously nasty in so many ways, and way more trouble than they're worth.
PS ... are the new straws adjustable for volume? As mentioned earlier, I do everything at the low settings on the old style can.
Unfortunately you cannot put the old style noozle to the new can. However, if you still want to get the old style can & noozle, you can get the mini-spray version:They leak, they fall off, they get knocked off, they get stuck, and when the entire head falls of the can, it of course has more than enough lumps and such so it'll get caught in the most inaccessible places instead of falling through. dOH!
Then again, maybe it's just me, or early production. And we're not talking the same sort of issues I'd expect to face on the radio bench, so forget I mentioned it.
** Will the old style nozzle still fit the new cans, just in case this ol' dog don't want to learn any new tricks? I'm assUming I still wouldn't get the adjustable spray if I did a swap?
PS ... thanx for the heads up on the D5 needle bottle. As mentioned, that's THE way to go when trying to avoid slop in tight areas.
