sabalennon
I have just took the capacitors out of this power supply, and I'm a bit worried about those brown-ish spots that formed around the connections, do these look like I burned the board? and if so, anyway to "fix" it? I have read that burning things is unlikely if you're careful because not many things in a power supply are not resistant to heat. But these definitely looks like burn marks, although some of the already existing connections look like they have some brown spots around them as well, but I'm not sure if they're the same thing.
I used a 30W iron to desolder and take the capacitors out, I am pretty sure I did not touch the actual board, just the connections.
EDIT: I decided to clean the connections with isopropyl just in case it was something superficial, it was, it came off and now the board looks green again. What was it?
