Value-wise many times the score that the amp is...Nobody has really mentioned it specifically - that Altec 604B duplex driver is very desirable. It's one heck of a mono system there.
By the way, do not plug the amp in again unless there is a speaker connected to the outputs (I strongly recommend against using the Altec at this point), you run the risk of frying your output transformer, which is excellent quality. Tube amps should not be powered up without a load on the outputs.
Whoever built this power amp initially did a spectacular job of wire dress. Study it closely and try and match the style if and when you perform any repsirs. Clearly the builder took great pride in their work and was very experienced in building electronics. I would be inclined to restore this out of respect for the original builder. Also it will sound fantastic!
Was the driver in the cabinet? Without an enclosure bass will be non-existent, but in a proper cabinet they are capable of just under 30Hz. They like large cabinets but you'll still get excellent lows from 5-6cu ft. My cabinets are 20cu ft...Yeah I kinda figured. I'm waiting hoping to get the rest of the guts from that cabnet. And I did hook the altec up to a marantz receiver and there was little low end. Maybe the crossover? It's an n-1000b. Haven't opened the case but I might be able to re cap that myself. Tall order for my first solder job tho. Lol.just wish there was a technician shop around here. Shipping things is sketchy.
Yeah it looks more than 6Was the driver in the cabinet? Without an enclosure bass will be non-existent, but in a proper cabinet they are capable of just under 30Hz. They like large cabinets but you'll still get excellent lows from 5-6cu ft. My cabinets are 20cu ft...
Some people put them in open baffles and report good results, but low bass will be considerably less than in decent sized reflex cabinets.
