Hi, thought I was finishing up a successful Model 5 recap, 1st one was great and sounds terrific. On the second one the cover was complete and begat to reassemble...cover back in, sealed, replace putty on midrange, reinstalled mid range all good. Put the tweeter in (I know it worked prior, after I connected it and tighten it down (maybe a little too much) I was working on the woofer and I heard a pop...sure sounded like it came from the tweeter but I though no how can that be I haven’t hooked them completely up yet...thought must have been water/flux some got onto my soldering iron. Finished everything hooked up both speaker second one has no high end. Went to UTube and played 20-20khz tone, first one great, second one cut completely off around 3800Hz.
what happened here, how can anything happen without being hooked up, what is my fix?
I figure if I hooked things up wrong I would have problems once I tried to use them but it was still half apart. I am quite certain something happened right then but am at a loss as to the cause so therefore the solve — appreciate
