Sorry, I don't find value with instant Cowboy audio comparisons. I find that long term listening is the only way to fully ascertain the capabilities of a component.
Perhaps you might want to review how I actually use the Touch player instead of using erroneous speculations.
So, which recordings were used? Kindly show documentation.
Isn't that a pretty important part of the test?
Aside from the logistical challenge of having to listen on the floor, the real question is: why? To play a game?Can you not use your computer and Shure ear buds? If they were good enough for you to hear distortion 32dB down, surely they're good enough for this.
A better way which has been done by Frank Van Alstine is simply to measure interactions rather than assuming none exist. On another board, someone brought the following cable test to my attention:Regarding the issue of "bogus boxes", perhaps you could first determine your ability to identify whether or not an AB/ABX mechanism is in the path? Or is it your implicit contention that there is really no way to objectively test your assertions?
As for me, I find that asking questions is more effective than making unsupported assumptions. Sorry, the "For how long have you been beating your wife?" line of questioning doesn't work with me.It seems quite clear that dumptruck was attempting to understand how your system is so much better than the system used in the referenced trial.
Look in the mirror.This thread is definitely circling the drain. It shouldn't be too much longer before a moderator shows up and locks it.
Simpler solution: choose to not read the thread. Or better still, choose not to respond.If you're tempted to post another thread like this in the future, will you clarify in the title that the "engineer" whose opinions you've decided to share is an audio recordist rather than someone who's knowledgable about information theory or electronic circuit design?
... Simpler solution: choose to not read the thread. Or better still, choose not to respond.
Your call.
Evidently you missed the fact that I linked to that document in post #28.You do actually read the authors and studies that you bash, right?
You are free to accept - or reject - the language and a commonly acknowledged profession.Or you could use the word "engineer" properly in your thread title rather than floating the implication that the opinion belonged to someone who actually knew something useful about digital audio.
Guys like Bernie Grundman would simply smile at your assertion.![]()
...I trust you certainly understand that both Meyer and Moran's degrees are in the arts, not science. Moran's background is literature and history. Look again at the credits.
It is evident you don't appreciate the difference between the onboard DAC/op amp found on an Intel motherboard with IEMs vs. my main music system if you say such is "good enough".
