JP
7480 74111110101115
I can say things as points, clarifications, or to elucidate my thoughts without having them mentioned previously by you or anyone else. This does not mean I'm putting words in your mouth. If I were, I'd say something deceptively clever, like "you said..."
If someone says 'copy' in the digital realm, that implies the bits are the same, hence bit perfect. The general subject Allen delved in to after the CD comment was digital generations sounding different. If he meant he had a CD produced and it sounded different because the bits were different, we wouldn't be discussing anything. However, he said CD copy.
BTW, I said: "For a copy of a bucket of bits to be degraded, there has to be a difference. Discounting corruption and errors which are easily detected, there is simply no difference in a bit perfect copy."
You said: "That's the theory, isn't it?"
Again, 'there is simply no difference in a bit perfect copy." "That's the theory, isn't it?"
Are you not stating here that you believe my statement above is a theory? Would that not then imply that you don't believe it to be factual and provable?
On the generations test methodology, I did explain it, in that paragraph. I could state it again, but I'd just be saying the same thing. Perhaps you can tell me what, specifically, you don't understand or would like clarified.
When you say "engineers", you mean audio engineers, not actual digital signal engineers, right? You do know that just because someone is a professional or otherwise aware of psychoacoustics, that doesn't make them immune to it? The filtering the brain does on the sound we process and the associated tricks and biases apply to everyone, whether they're a professional or not.
No ABX box.
No ABX box.
