Rick Vestal
Have a nice day and duck!
Appears someone just heard the term brickwall recently and now is trying to apply it. Too much misinformation in this thread. I'm outtie...
Engineers do that all the time since they can do what is truly the only valid comparison - live vs a digitally processed feed. Like post# 7 from a Disney engineer who does both movie and multi-channel work.Do you have any empirical evidence, i.e. double blind or abx comparisons, that show that redbook is "crippled"?
The development of oversampling and digital filters have rendered those "problems" insignificant. I have seen no dbt that demonstrate that redbook standard is inadequate for playback files. Do you have any empirical evidence, i.e. double blind or abx comparisons, that show that redbook is "crippled"?
Fine. We all know the underlying problem is the unavoidable ringing and phase errors introduced by a brickwall filter that has to completely suppress all content in the space of one-tenth of an octave.
That's the real problem. Higher sample rates don't require that crutch. You won't find a single speaker on the planet that uses a brickwall filter for obvious reasons. Many in fact use 6 db/octave single order crossovers to ensure phase integrity.
If you're going to quote me, then quote what I actually said!How is that a valid comparison? "Digitally processed feed" A versus digitally processed feed B is what you're talking about, and engineers compare them all the time, but almost never actually ABX, even though it is easy for them to do.
Sorry, that statement is not supported by fact. A brickwall filter is simply one with a very steep slope. When you must suppress 100 db+ in the space of 2k, that requires a brickwall filter. Period.Get with the times, E-Stat. Brickwall filters haven't been used in digital recording or playback for at least twenty years.
That's the funny BAS test to which I refer!! Have you actually read the details of Meyer and Moron's test or what was used? It would seem you haven't. And they most certainly didn't compare a live feed vs Redbook vs. SACD.Two AES members did a double-blind experiment in 2006 that demonstrated the exact opposite. The AES paper that reports this result, "Audibility of a CD-Standard A/D/A Loop Inserted into High-Resolution Audio Playback," is by E. Brad Meyer and David R. Moran.
That's the funny BAS test to which I refer!! Have you actually read the details of Meyer and Moron's test or what was used? It would seem you haven't. And they most certainly didn't compare a live feed vs Redbook vs. SACD. ...
While more than one SACD player was used, they employed a $300 Pioneer 563A DVD-A/SACD universal player during testing to represent the state of the art. ...
And you take that test seriously? Ok! I was made aware of it shortly after it came out over five years ago. And do recall one of the conclusions from the test:I read the entire paper back in February when I printed a copy. That's how I could provide the title and the authors' names, which is more than you did in your earlier post.[
I have no problem at all with the conclusion that mid-fi systems like the one they used are incapable of providing the highest level of audio performance.If the difference in sound quality between hi-res digital and CD is as significant as you and other hi-res proponents claim, that $300 player should have been more than good enough to make the point.
"Though our tests failed to substantiate the claimed advantages of high-resolution encoding for two-channel audio, one trend became obvious very quickly and held up throughout our testing: virtually all of the SACD and DVD-A recordings sounded better than most CDs—sometimes much better."
Sorry to hear that.I've heard SACD, DVD-A and CD back-to-back on a very high-quality system. With the system set for two-channel playback instead of multi-channel, I could not reliably tell which player the system's owner was using as a source.
Two AES members did a double-blind experiment in 2006 that demonstrated the exact opposite. The AES paper that reports this result, "Audibility of a CD-Standard A/D/A Loop Inserted into High-Resolution Audio Playback," is by E. Brad Meyer and David R. Moran. The authors conclude that SACD or DVD-A playback that's "bottlenecked" by inserting a 16/44.1 A/D and D/A conversion between the hi-res player and the amp cannot be distinguished from a direct feed in a properly-controlled double-blind test. The listening panel correctly detected the presence of the bottleneck loop in 49.82% of the trials, which equates statistically to random chance.
Sorry to hear that. ...
If you don't trust your ears and require graphs, then look at the spectral output of CD players. All steep anti-alising filters (aka brickwall) cause ringing.Right, i'm asking for tests that indicate 16/44.1 is inadequate.
That's a different question. For most folks, lossy MP3s are good enough. That's not what Moron, et. al. attempted to prove.At their best, CD and LP both get me close enough to the real thing that I see no need to spend money on SACD or DVD-A.
Actually, I share that sentiment and never purchased a SACD player although I've heard exceptional EMM Labs players in an audio reviewer friend's phenomenal systems on many occasions over the years.I've probably saved a small fortune by not buying more gear and re-buying my favorite recordings on yet another medium.
See? The rest of us just listen to the passion that is music and enjoy!I want to see level matched, double blind comparisons that demonstrate there is a statistically significant audible difference.
Measured differences =/= audible differences. You well into diminishing returns with these sort of comparisons.
If 16/44.1 is "crippled" there should be ample empirical evidence.
Where is it? All you are posting are anecdotes and opinions.
