I never put words in anyone's mouth. Going back and reviewing the thread, the conversation follows the inference that digital copies suffer degradation. I said bits are bits, and you called that a theory.
Bias and psychoacoustics aside, of course when you look at an entire reproduction chain there are tolerances and differences, audible or not. But that wasn't the indicated argument in your comment of bits being bits a theory, nor was it the discussion Allen had.
If Allen gave the production house a CD (probably not) or CD image to produce, the production should have been bit perfect with the source he gave them. If it wasn't, there was an error or they changed something, and if that's the case one can't say that the difference he claims to hear was caused by generational degradation of digital.
As for copies being bit perfect, aside from the simple fact that this "phenomena" doesn't exist anywhere else in the digital data world aside from audio, I've tested it. We did 10,000 generational copies of a wav file. All 10,000 copies were bit perfect, and predictably taking the first and last or random samples for ABX, no one could hear a difference.
With the proper test equipment it's very easy to check a CD for data errors (both soft and hard), to measure jitter in a bit stream, etc. While there's lots that can go wrong, it seldom does, particularly with competently engineered components.
The chances of the same reproduction chain manifesting audible errors consistently between two different but bit identical CDs that can be read without unrecoverable error in a repeatable and predictable fashion are none to none.
If I'm misunderstanding the position your advocating, please let me know.
Oh, and on the high res vs. Redbook argument, it's really simple. Take a high res file, convert it to Redbook (level matched and all that jazz), and ABX them. I've a friend that's done this with dozens of people - no one can hear a difference. Dead simple for you to try yourself.
