See? The rest of us just listen to the passion that is music and enjoy!
To each his own.
Yep, that's what professional recording engineers do every day!Indulging in confirmation bias is less work and more fun than doing a complete engineering analysis, after all.
Burning straw men really is a pointless pursuit. Would you like to address anything that Allen actually said and try again?Subjective/objective aside, I want to hear more about how bit perfect copies suffer generational degradation.
Yeah, we've got to be vigilant against all the charlatans in the industry both in the recording and playback side (that would be hundreds of companies) who find high resolution recordings are better!while determining that _____ has no actual benefits in the end product
That's all you'll ever get from the subjective side of this hobby. Indulging in confirmation bias is less work and more fun than doing a complete engineering analysis, after all.
Translation: You'll stop putting words into other folks mouths they never uttered.Sure, I'll play your game.
Thank you! Now we can discuss something other than your imagination. My reference was specifically to his comment about the master going to the replicators and not sounding the same.Allen said he couldn't make a copy of the CD that sounded the same as the original. You inferred you have experienced the same or similar re: generational degradation.
True science and logical analysis should be assumption free. Why do you assume that to be the case? What is your control?Using my own words, a copy, if it's truly a copy, would be bit perfect.
At the expense of confusing the issue with facts, we don't hear binary digits. Do you? What does a "1" sound like exactly?So, how is it when all the 1s and 0s are exactly the same between multi-generational digital copies, degradation is claimed to have been heard? Really, any audible difference for that matter.
Sorry to hear that.
I have several sets of music recorded on LP, CD and 24/96 FLAC and observe the contrary. While LPs and CDs each have their own set of tradeoffs, I find that hi-rez finally blends the best of both worlds.
We hear the end product of a complex chain of components that must read, correct, decode and convert those digits into a signal real time. There's lots to go wrong. And does. If your world, like that of Dr. Tinear, is limited to $300 players, then there's little to discuss.
As my post suggests, there is a counterpoint to Monty's position that the industry is all wrong offering high resolution recordings. The rest of us just enjoy them.Good for you, still fails to prove your points though. Cause what you find is just what YOU find, someone else might find something else.
When you trust reading Rob's straw men arguments instead of referring to Allen's specific comments, then there's nothing to say.And as for digital copies degrading, that is so laughable that it renders the other information the source comes up with completely irrelevant.
Yes. I enjoy them downsampled to 48k, usually.As my post suggests, there is a counterpoint to Monty's position that the industry is all wrong offering high resolution recordings. The rest of us just enjoy them.![]()
Well, we all look forward to your ABX results using your expensive playback gear where you identify your hi-res formats compared the same files after downsampling. Oh, right, you just enjoy the music. Well, fortunately those "hundreds of companies" you mentioned earlier must have taken a few hours to prove at least one person somewhere using something can tell... anybody? no?If your world, like that of Dr. Tinear, is limited to $300 players, then there's little to discuss.
Absolutely. I suspect most every one. It was an expensive venture at first to introduce new recording standards that are now universally accepted.Well, fortunately those "hundreds of companies" you mentioned earlier must have taken a few hours to prove at least one person somewhere using something can tell... anybody? no?
...If your world, like that of Dr. Tinear, is limited to $300 players, then there's little to discuss.
In the original thread, I asked if Monty ever addressed the inevitable ringing resulting from steep anti-aliasing filters. Never got a response. Do you know?If this is the best counter argument the OP can find to cast doubt on Monty Montgomery's technical demonstration using universally accepted test methods, then he has failed horribly.
Showing test tones on an o-scope is kinda cool, but completely misses the point of why sampling at higher rates is desirable. Which Allen did mention. No steep filters required to ensure Nyquist is satisfied to capture 20k.
