oldNslo
Member
Ok, those with far greater knowledge, I have a few questions as I proceed forward with a replacement part.
The left image is from the Yamaha SM, the right is from Mouser for a DB105. The OE part is WH471700 (not seemingly obtainable) however is marked DB105 on the component on the board now.
Q1 = are these 2 electrically equivalent? Is 1 less diode just a result of getting smarter over the years?
Q2 - Is the right image "tested" in the same manner of a bridge diode? (ie reversing the test leads)
Q3 - I'm presuming I need to get my DC leg orientation correct, and would be indifferent to the AC leg orientation. Is this correct?
Thanks in advance!
Thanks in advance!
