Distorsion sound when Powering On NAD 3020 ?
liemjerry
Well-Known Member
Hello
My NAD 3020 is rarely used.
Today I am powering on this NAD 3020 and found a while distortion sound from my speaker and then it dissapear, why this is happened ?
Thank you
Those 3020's are known for bad/weak/failing solder connections. Can't say where your problem lay but I'd wager that the more closely you look at the board's solder connections, the more suspect one's you'll find.
Is the noise there even when there is no signal playing? If it's just static sound, then that would support the power switch arcing answer above.
Is it just in the first second of startup? Or does it last longer?
The disturbing sound just appear in a few second after switching on the button, but about 10 seconds at least the sound disappear
A long shot would be bias not correct, check/set as per service manual. There are 3-4? versions of the NAD3020, with differeing main
filter cap placement and,,, need to get the correct sm/bias procedure.
I'd better send to service agent I recognize :)
