DIY Merrill record cleaner
I have found that pencil in the hole held at the right angle under running water in the kitchen sink will turn under the running water. Then lay LP on a diaper and use a cleaning solution and a DiscWasher brush or a nice paint brush works good too.
I use this method too but prefer to use a screwdriver... Using a modified lazy-susan ( like those wood units from WalMart, Sears, etc) is great to clean/dry records.
Jose
Ha! You said:
snip snip snip
Also, what are you guys doing with this or any other RCM to let the vinyl dry? do you wipe them with something specific and then lay them out for a while? i would imagine putting them right back in the sleeve would not be good, even if you did pass a cloth or something over it.
Wipe with microfiber cloth and put in dishrack, or similar to air dry.
The pipe has a hole to let pass through the screw attached to the label protector ( which could be similar to the GEM caps or any Groovemaster clone). If you want it to rotate, you could use a pair of nuts. One that hold the caps and one which allow a little space to rotate the system. The caps need to be clamped but the pipe could have some space ( 1/16" is enough).
NUT/WASHER/CAP/LP/CAP/WASHER/NUT/PIPE/SPACE/NUT
Jose
How 'bout
NUT/WASHER/CAP/ LP /NUT/CAP/NUT/WASHER/SMALL GAP/NUT/PIPE/NUT
Clamp the inside cap between two nuts, should allow the thing to spin.
Would it be possible to add a small pump to it to make it portable, then use a small tip to get the spray to a useable level of power? Maybe a crimped copper end fitting? I would love to sit on my front porch and clean as the Girls of Summer stroll by.
You can do anything you want! That's the beauty of DIY! You can play with your hose and watch the ladies from your front porch. I'm sure it's illegal in most states though. Now how about those pictures:
It's late so bear with me......
II fixed clamp assembly(no album rotation feature here)
1. Cut 1 piece of pvc pipe to 8 3/4" long using the hack saw.
2. Staying in the center - Drill a hole 2 inches from the top through both sides of the pipe.
3. Cut the threaded rod to 6 1/2" long using the hack saw.
4. Using one end cap, 6 1/2" rod, 2 wing nuts, and 2 fender washers assemble as seen in the pics.
Tomorrow I'll finish posting the rest of the assembly, and discuss the importance of working in a well vented area. And no, my hair doesn't usually look that way.
JustW -- I think you'll need space on both sides of the pipe for it to spin. If you have a nut attached to the pipe on either side, it will basically fasten the threaded rod to the pipe. I've illustrated the configuration that I think would work:
And obviously the gaps would be much smaller, that's just for illustration. Any other ideas for better spinning?
That would work very well. When I first started to mess around with this stand I wanted to make it as simple as possible. The clamp is fixed to the stand and the user orientates the sprayer not the album. Either way it works! I've also just flipped the stand as well.
Derek
or just cut your hole in the pipe a touch bigger and put a sleeve over the threaded rod section
nut-washer-sleeve---pass through pipe----washer-nut
Yeah, like that. Thanx. this would be easier if I would stop PLANNING and just go buy the parts and DO IT. Over planning is one of my faults. Sometimes causes me to freeze and do nothing...
