1) replace 10 uF with 100 uF Caps
2) replace 100K with 200K resistors
Should 2.2uF caps be removed? (I want to be able to connect CNC & HTMCPS plus one AUX input) with LSA
1) You can use 100uf or 47uf caps.
2) You can replace the 100k with 200k resistors it will slightly lower the corner frequency. ie: slightly more bass extension, but probably not that noticeable.
With the 2.2uf caps in the SSP, they are for DC blocking, if you end up with DC offset these will stop it from reaching your amp.
You can safely remove the 1uf cap from the CNC and the 1.5uf or 2.2uf caps (depending on what you went with) from the HTMCPS IF you are running it through the SSP though. You can try shorting them out first with a jumper (don't put the jumper in place with it switched on) and see if there is any noticeable difference.
Kappa,
The 100K pot you asked about is the variable resistor for the LDRs, the 100k pot itself does not attenuate the volume. (signal doesn't go thru the pot)
Looking at the relay board you posted, I downloaded the spec sheet for the relays themselves, they look pretty good.
Bifurcated (Gold overlay silver-palladium), 5V coils, high sensitivity, non latching, 1A at our input voltage. Can't speak of the board itself, any documentation by the seller? It's got pretty black and gold caps thou.![]()
Price is right? Go for it and let us know what you think.
Ron
This is how LSA need to connect SSP, Where SSP input is fed by CNC phono or any other source.
Thanks for the recommendations. I will implement the changes to the build.
In regards to the 47uf caps, is this the cap for the opamp? I am curious in the changes made from the CNC, which the 10uf was used, and the HTMCPS & SSP now being recommend for 100uf & 47uf. Would these cap values may be related in some way to do with compatibilities of the opamps? As you have also noticed that some opamps seems to be more difficult to drive, i.e. LME49990 compared to other opamps for the input socket for HTMCPS. Would using 47uf in HTMCPS also help or would 100uf in SSP poses similar symptoms as HTMCPS for opamp compatibility?
Some opamps don't behave well in the input section of the HTMCPS, but since there are plenty of op amps that do it's not a problem.
The capacitors reduce noise and the 0.1uf ceramics reduce the possibility of oscillation. It's not that important if you use either 10uf / 47uf / 100uf especially if using batteries. But any of these sizes will help a lot if using a PSU, I prefer either 47uf or 100uf though.
