What you have to watch with the LME49990 is the decoupling. The gain bandwidth is so much higher that classic OPAs that you really need to start using RF decoupling techniques.
This is probably why some do and some dont?
All my high gain bandwidth designs are done on double sided PCB with a solid ground plane on top. The IC supplies are decoupled as close to the pin as possible, usually with 22n // 220n // 10u paralleled.
Maybe overkill but nothing has turned into an oscillator yet :nono:
Sellers response;
What you describe sounds like the op-amp is overheating from oscillation. The LME49990 is a high speed op-amp and requires special attention to local power supply decoupling. It's common to have this kind of problem when swapping a high speed op-amp into a circuit that was designed around a slower op-amp.
I'll give you a couple options here. If you send it back, I can put some decoupling caps directly on the module and send it back to you. There's a decent chance that will fix the problem, but no guarantee.
So is this the solution?
Thanks george
Thanks for all of the info.
I have no idea what most of it means, however my SSP works very well now with the original chip back in place and a 9v battery and I am extremely pleased.
george
Hi George,
Are you using only one battery to run SSP?Regards,
Sachin
Hey Sachin
Yes I'm using a single 9V.
Thanks
george
Many members are using LME49990 in SSP and CNC.I am also running CNC with Lme49990.I have set the voltage on +/-10.It gets very hot above that.
Regards,
Sachin
This still bothers me a bit, Sachin. Just because people are using them doesn't mean that they know the effects. If you push the voltage a smidgen too high, the opamp oscillates rapidly and gets very hot. Turn down the voltage, it cools down but is it possible that it's still oscillating and/or creating ringing, etc.? Besides frying the opamp (relatively cheap, yes), what are the possible negative outcomes? Can one damage the power amp the SSP connects to? I don't know the answer to this and am not qualified to answer, I'm also a worry-wort. For now I'll stick to an OPA2134pa.
You are correct! My suggestion was for the use case without pots and DC blocking caps.
Here suggested schematic in above post is missing that pot. With the use of either 25K pot at input or 1M resistor to refer input to ground, it is possible to eliminate DC offset while excluding that DC blocking cap. Also it does affect sound anyway.
IMO this is only suggestion with my own experience where I excluded pot and DC blocking caps. I measured 0.3mV DC that could be ignored. I wanted highest input impedance possible.
Regards,
Sachin
When these are mounted on a dual adapter they share the same supply rails, which could cause oscillation due to variances in current draw?
That's my theory. :scratch2:
Has anyone else tried this? I'm using the OPS and not batteries, so I think it would be safe. Anyone have a pic of what this looks like and a procedure for doing this mod on the ssp?
Exactly my thought.
Regards,
Sachin
Ok so the blocking caps stay. I see that some people are using 100uf caps instead of the 10uf in the BOM. Is there any benifit to this if running off of OPS?
That's interesting about the ad797, I look forward to your review, I'm really liking 2134 so far, very neutral and relaxed.
I would like to try the ceramic cap soldered to the power input of the adapter for the 49990, so I could run it at 15v without fears of oscillation, which pins on the adapter do I connect it to?
Hi all,
I got 4 chips of AD 797 from Sachin a couple of days back. So soldered a pair onto the stock adapters lying with me, and used this in my SSP. Initial impressions are that this chip is very detailed, and has better HF response and mid-range than 49990. Will have to wait for another 25 hours for this chip to settle down. Will update the thread after that.
Just thought I will post my impression.
N.Murali
