If I want to try the OPA2134 I should use the same adaptor as the AD823, correct
Yes, any dip8 machined adapters with round legs like the one you posted a link too will work, just not the ones with the square legs.
That isn't an adaptor, it's a socket.If I want to try the OPA2134 I should use the same adaptor as the AD823, correct
This one:
http://www.mouser.com/ProductDetail/Mill-Max/210-43-308-41-001000/?qs=sGAEpiMZZMs/Sh/kjph1tvt1/mEPT/XonwUiB5bp7l8=
Both opamps are PDIP-8 so I assume the same adaptor will work?
You will love the phonostage too.Got this all put together a couple weeks and have enjoyed it tremendously! A definite step above the late 70's Japanese stuff I'd been using!
Haven't got the phono stages built yet...but almost. Can't Wait!!
Thanks Again!
The Pass B1 is excellent, unity gain tho.Can't help.
I have a Pass B1 buffer stage in the starting process.
I also built one of these
https://audiokarma.org/forums/index...p-elliptic-filter-line-headphone-amps.937686/
It's very good.
Let us know how that turns out.
I've lately been interested in trying low gain preamps and after reading about Rod Elliott's design here: https://sound-au.com/project88.htm I wanted to know if it could be made single stage. This great thread was a lucky find - it essentially answers that exact question. Thanks to all the contributors.
I just have to get a few more parts and then I'll be attempting to build this and a power supply on a perfboard. There are a couple of queries I have though as, unlike the first gain stage in Rod's preamp (above), the SSP omits capacitor C1 and resistors R1 & R2 at the input.
Are there any cases that would require the use of the input capacitor (which I assume is for DC blocking) in the SSP?
The SSP has a potentiometer at each input. If those are not used then would R1 be reinstated? If I understand correctly, the value of this resistor is the input impedance.
Any clues as to what R2 does?
Sorry about all the questions. I'm not out to unsimplify the simple preamp, just further understand it. Attached is my proposed schematic for the SSP and PSU. If anyone has any comments on it they'd be appreciated.
Quite right,
Most often you don't need gain . Why many try passive preamps.
The B1 should give adequate drive that a passive might lack.
I've never been inclined to go the passive route. I do like simple though. I've found simpler amp and preamp circuits sound more organic to me. Obviously YMMV.
I recently finished an F5T and figured it'd like a family member in the mix. We'll see
