What can you afford? That's what it really boils down to.
With a low power limit like 4 watts, the original 604 or 604B with proper original paper hinge and phenolic spider moving assemblies and N1000 networks would be ideal. You'll pony up a minimum of 5 or 6 grand for a pair. Your budget will dictate where you;re going to go with 604's.
IMO, a Markwart phase corrected network is about the minimum standard, although the later factory networks with mid and high attenuation are an acceptable starting place for 8 ohm models.
