Preamp or amp? First post is about preamp but most of the ones after are about
ampIifier kits.
I have no experience with kits and I'm not a fan of circuit boards. If non-kit DIY is an option, I built this a while back after going through a lengthy breadboarding process during which I auditioned about 10 or 12 different types of tubes:
https://www.audiokarma.org/forums/index.php?threads/1626-preamp-build.931276/
Simple circuit, inexpensive and easy to build. Additional features, such as multiple inputs and even remote volume control could be added if desired.
I've also gotten good results with another preamp recently but it is not a kit and not DIY.
It's a super basic, no frills, Chi-Fi cheapie that uses directly heated tubes. I picked it up because one of the tube types I liked during my breadboard adventure was the Russian 2P29L, which is very similar to the tube this uses. Perhaps too basic for you, though.
https://www.audiokarma.org/forums/i...e6-preamp-uses-directly-heated-tubes.1009865/
One thing about the "clone kits" is that they are almost never actually clones. That doesn't mean they might not sound OK but "inspired by" is typically more accurate. You really need to compare schematics to see how closely they follow the original. Some are much closer than others. I recall seeing one where the only resemblance is that they used the same type of tubes, the circuit was not even remotely similar.
And, yes, you can count on them coming with cheap parts. Even if the parts carry "name brand" labels they are often counterfeits if the kit is Chinese. If you're going to replace them, why buy them in the first place. Start with quality parts from a major distributor.
If you're limited to building a kit using a circuit board, you might want to check out one of the Glassware offerings. Much higher quality than a Chinese kit from eBay. Maybe even cheaper? If you end up using just the board from the eBay kit a board from Broskie / Glassware is definitely cheaper.
https://glass-ware.stores.yahoo.net/newhardware.html
StepheK's YT channel is a great resource for DIY building. She compared some popular preamps, some of which are available as kits, a while back. Here's the summary, search her channel for the build videos. At least one was built from a kit (??):
She also did a four part series on how to add headphone capability to an amp:
As for the amp you linked, I read the description and they claim that it puts out 4wpc when running the 6L6GCs in triode mode. The 6L6GC data sheet says SE triode produces only 1.4w at 5% distortion so Elekit's claim (despite their good reputation) is obviously a fantasy. Either that or the distortion must be through the roof, more suited to a guitar amp.
In pentode their claim of 8.2wpc is reasonable. Pentodes require negative feedback to operate linearly. When I see amps that are switchable between pentode and triode I wonder if switching also eliminates the feedback or if they run feedback regardless of the mode of operation. I suspect that the cheapest kits just ignore this aspect but perhaps Elekit deals with it properly. You might want to ask if you're considering buying it.
