Califmike33
Well-Known Member
That is just so ridiculous what a world we live in when you have to fake capacitors potentiometers and electronic parts.
I've built the ST-70 amplifier and a pair of the M-125 mono blocks. Solid kits with great instructions and they sound very good. As for the preamps, I haven't had any exposure to those kits.
I don't think it has much to do with the type of amp. It's mostly about impedance matching.I got another question for you guys do tube preamps pair better with a class d amp or a class a b?
Sounds like total BS. What, exactly, is "missing" with a class D amp? And how does the preamp know what's missing, and what does it fill it in with?I guy i follow on youtube THOMAS STEREO says that tube pre amp fills the gap of whats missing on class d amps and they work well.
Yeah, total BS.He talks about what's missing on class d amps that they tend to sound dry etc etc and a tube preamp sort of fills in the areas that are missing on class d according to him.
Well I'm a tube fan and I seem to prefer a setup that includes tubes. Of course this is all subjective and YMMV. And, while I prefer an all tube setup, I do enjoy the Class D amps I have too.I guy i follow on youtube THOMAS STEREO says that tube pre amp fills the gap of whats missing on class d amps and they work well. He claims its the best setup is a tube pre and class d amp. . . . Trying to decide if i want to go full tube for headphones and speakers or go preamp tube and class d for the amp, hmmmmmmmmmmm.
Im a little nervous charlie about building that boggie factor amp, point to point looks hard vs PCB.
I can understand how you would be overwhelmed and, yes, it's hard to guess how something will sound. That's why I prefer to breadboard projects before I build something.I'm looking at that their marantz 7 circuit another maybe a carey circuit another one I was looking at is a rogue circuit copy clone. No I have to admit I don't know anything about those circuits but I'm guessing if they're trying to clone it they must have some type of reputation to the original. . . . it's a little overwhelming cuz there's so many of them to choose from and I have no clue what they sound like.
As for that simple preamp, as I said, you really don't need anymore gain than what a 12AU7 will provide. I just found the the 12AY7 sounded better to me.I can understand how you would be overwhelmed and, yes, it's hard to guess how something will sound. That's why I prefer to breadboard projects before I build something.
The Chinese will clone anything but they seem to mostly choose circuits from companies that have some brand recognition so they can capitalize on that. I seriously doubt that their decisions are based on sonics and they often call them clones even though they don't follow the original circuit. It's not just the Chinese, of course. Tube manufacturers sell new production "Tung-Sol", "Gold Lion", "Mullard", etc tubes in an attempt to capitalize on the reputation of the original companies. Unfortunately, tube newbies often don't realize that the tubes are not the same. But I digress . . . as I often do.
For example, StepheK's first "preamp shootout" on YT included 3 preamps. One was the popular Marantz 7 "clone", which was the one she considered the worst of the 3. And two of the three sounded like SS, not tubey at all.
She's planning a updated shootout soon which will include the winner of the previous one and 4 others. The details on those plans start at the around the 11:40 point in her latest channel update here:
She will be including the one Lavane built. She also built one of those after the earlier shootout and liked it. She has a detailed, step by step, point to point, build series on it:
That basic circuit design is the same as what I used in my Boogie Factor 1626. As you can see from the pic Lavane posted, there really isn't much to building something like this. Not quite as simple as soldering parts to a circuit board but not really complicated either.
I'm usually a bit skeptical about designs that are meant to appeal to tube rollers. The ideal operating points of those tubes are all somewhat different. Unless there is some provision to adjust the operating points, there are bound to be compromises made in order to allow for tube rolling. If it was optimized to use a particular tube type, the operating points / parts values might be different.
For example, it uses a 100k plate load resistor. Another "rule of thumb" says that plate resistors should be at least 3x the plate resistance of the tube. The 12AX7 has a plate resistance between 62.5k and 80k according to the data sheet.
Also, I notice that @Lavane says that it works well with all the tube amps he's used it with. But what about SS or Class D? Perhaps he'll comment. It seems like most of the interest in tube preamps is coming from people who want to add that proverbial "tube goodness" to their SS / Class D systems.
The output impedance of a simple design like this is mostly determined by the plate resistance of the tube. For example, the 12AY7 has a plate resistance of 25k ohms. So, on paper, it doesn't even follow the rule of thumb for a tube amp with a 100k input impedance and it's very far from a Class D, which might be as low a 10k or 20k.
BTW, the SE 6BQ5 amp that Stephe uses in the shootout was built from one of my projects. It's good for comparing preamps because it has no input tubes, only the 6BQ5 output tubes. Its input impedance is quite high at 470k, so it's very easy to drive and, as a result, input impedance issues are less likely to be apparent.
But again, I'm not sure how audible an impedance mismatch might be. Perhaps it's not audible at all. I don't usually concern myself with things that are not technically ideal if they aren't audible but when I build stuff I do try to respect guidelines like this when I can.
For example, when I was breadboarding tubes for the Boogie Factor I only tried low gain tubes, mu of 10 or less, because that was the prime design consideration. It's based on the premise that, since most amps don't need any gain at all to produce full power, why use a high gain tube and then dump most of the gain to ground?
I chose the 1626 based on how it sounded to me, although a couple of others were close. I calculated the output impedance as ~1.39k but, truthfully, that aspect was not one of the prime considerations. If I had liked the sound of another tube better I would have used it even if the output impedance was considerably higher. But it is a nice bonus and provides a better "on paper" impedance match with SS / Class D.
OK, earlier I mentioned seeing a pic of a tidy breadboard build which demonstrates how you can build something without building a chassis and with almost no soldering. Not recommended if you have small kids or curious pets, though I suppose you could add a cover if you find that style of construction appealing to you. Here's the pic:
