Dlk 1.5
The ones I'm talkin' bout are just listed as Saint Paul. Picture of 'em in front of a white sedan. I wish I could snag those DLK 3's in Plymouth but my bride would have my head on a platter before I could sneak another pair of speakers into the house without first having to move a pair out. :tears:
Can't find them. Could you PM the link?
Those aren't the right "Style" for me. They have the velcro grille.
I'd still like more DLK's!
anybody know the value of the dlk/2's. i have a pair i'd like to sell but don't know what they are worth. one is perfect and one cabinet has has some work done and is missing the nameplate strip. you can see the issue with the one cabinet's top corner.it was glued and nailed back together. it not pretty but it is solid. the pic was before both were oiled to show before and after.
Here is the little I have picked up over time since I picked up my Model 4's:
The company was a wholly owned subsidiary of Schaak Electronics based in Minneapolis MN. The name is derived from name of the engineer Donald L. Kliewer. Don was an excellent engineer and had a state of then art lab for the time based on Bruel & Kjaer test equipment. The company originally made speakers under the Omega label and later developed a higher end line under the DLK label. Don did extensive testing of drivers and in the DLK line did not use off the shelf drivers but had them slightly modified to his specifications and 2nd order x-overs were used in all models. All the DLK speakers were made of ¾” mdf and had hand rubbed oiled book matched walnut veneered cabinets.
The DLK Model 1 was the first speaker in the line. It was a two way design using a Phenolic Ring tweeter and an 8” paper cone tweeter with a butyl rubber surround.
The next speakers were the Model 2 and 3. Both these were three way designs with the woofer and tweeter in phase and the midrange out of phase to smooth the x-over notch distortion, a common practice then. The Model 3 was developed first and the Model 2 was a modified 3 made to be smaller less expensive. The 3 had a 12” woofer with a foam surround in a sealed cabinet. A 4.5” paper midrange with a doped fiberglass surround in a sealed sub-cabinet. The tweeter was a Matsushita doped cloth dome with a sealed back. This tweeter was very cutting edge at the time. The model 2 cabinet had the same height and width as the 3 but was not as deep and was ported. The woofer was nearly the same as used in the Three but had a doped folded fiberglass surround and a smaller dust cap and was designed for the ported cabinet. The midrange was the same and the tweeter was the same as used in the model 1.
After the 2 and 3 were released there was a need for a model between the 1and 2 and DLK 1 ½ was developed. This was basically a Model 1 with two 8” woofers and the cabinet size increased to load both woofers. There was also a Model ½ and ¼ released later. The ½ was a sealed two way design with a 6” woofer with butyl rubber surround and a paper cone tweeter and the ¼ was a 41/2 full range driver in a small ported cabinet. The ¼ could be seen on the back deck of many cars in the seventies in the early days of car stereos.
The final speaker was the DLK Model 4 which was basically a 3 with two 12” woofers. This was known for its large size almost four feet high and it’s cultured marble top. The x-over in the model 4s were made in pairs with matched drivers and x-overs and all the capacitors were large Mylar sand filled type.
Thank you,its been many years since I have seen that photo or a likeness to it. Being raised in the twin cities it is impossible to not To know about DLK. One item ,i s I was told be old friend who were in sales at schaak that the DLK 3 was first to appear,Esspeclly in the profitable Mall stores in the twin cities(Burnsville center,southdale,rosedale,brookdale,etc) then the 2 and 1.5 came out. I never remember seeing the model 1 except in the late 70s as a lot speakers with lower power receivers(a mistake as the one hadles a great amount of power for it size and set up.
Thank for a very informative history on DLK .you may be right,as I approach 60 years old,most DLK info is from the menorys of guys my age. We may be losing some marbles.
I remember the 1977 Minneapolis Star)Tribune article on DLK. I had purchased a pair of Marantz HD770 from a local in the walk warehouse that the geeks used to buy Marantz z products at. Midwest Stereo on Lyndale Ave in Bloomington MN. They sucummbed to the best but crazyness that kill compatition in the twin cities. ,After reading the DLK article I went to a Schaak still in Burnsville center(about the biggest mall in Minnesota until MOA. After spending many hours with tape and the DKK 2&3 I ended up makinging a killer deal in 1979. 400 for a pair of 3s. They did not have the high end of the DR ED MAY designed (JBL fame) Marantz line,but that crossover was much more sensitive to me on the DLK 3s. I kept both pair until the late 80s. As DLK was gone I figured the Marantz would be easier to get parts for. Big mistake on my part. The amount of DKK sold in Minnesota was massive. So it is fairly easy to find parts for all but the model 4 in IMHO. And the people who say use a tube on DLK are absolutely right. My father had a massive GE consume stereo with a 30wpc tube amp with a output for a 2nd set of speakers. I will not say it blew away my Marantz 2265,but the sound was remarkable. I am so lucky to have found a set of 3s in 2005 that are in near mint shape(except for the pots) and a nice set .of 1.5 that I am slowly refurbishing.
If a pain can afford to keep multiple sets of DLK ,I would do it .no many better designed speakers in the world.
