dlucy's guide to Harman Kardon Stratophonic series SR300 SR400 SR600 SR900
dlucy
dlucy67 (Doug)
Staff member
Moderator
The first solid state receivers from Harman Kardon were the Stratophonic series.
This thread is a guide to those models, their specs, and pointers to schematics and restoration threads for each. If you have additional information on any of these models, send me a private message and I'll get your info inserted into the right spot in the top posts.
The Stratophonic units looked a lot like the tube units they replaced and relied heavily on Germanium transistors.
Their was an initial release of Stratophonic receivers and then a second generation, otherwise known as "the B-series", with mildly better specs.
Initial release:
The follow-up release were improved models:
"The B-series ... includes diffused-junction germanium transistors in all output circuits. Germaniums increase bandwidth and reliability, are far cooler in operation than any other silicon transistor now available."
The Harman Kardon Stratophonic receiver series pre-dated the Harman Kardon Nocturne series, the 330/330A/330B series, and the Twin Power series.
First Stratophonic models – SR solid state stereo receivers
  • The SR300, and it's relatives, SR600, SR 900 were h/k's first attempts at SS receivers, hence the look of a modified tube chassis.
  • The SR300 was part of the first series of SS h/k receivers and was $220 in 1964 dollars. It would be $1,606 and change today.
  • Descriptions from ads for Stratophonic FM Stereo receivers
    • “a complete all-transistor line”
    • “According to the HK site SR300B "Stratophonic" was only made in 1964!”
    • the first transistor units after the tube era and still built on the old chassis.
    • "You should also know that it is the culmination of several years of intensive research in solid-state technology. Your Stratophonic Receiver is LITERALLY born out of space-age development."
Second series – SR “B” solid state stereo receivers
  • Descriptions from ads:
    • “greatly increased power, far wider bandwidth, flatter frequency response at full power” and drives speakers in two rooms, separately or simultaneously. Germanium output transistors.
  • Models are SR-300B, SR-400B, SR-600B, and SR-900B (the ad uses a hyphen but the units themselves omit the hyphen in the model name)
    • SR-300B – FM stereo receiver. Same as SR-400B but without AM. 60 watts IHF, power bandwidth 6 Hz to 50 KHz, full-power frequency response 8 Hz to 40 KHz. FM only. $279
    • SR-400B – AM FM stereo receiver. Same as SR-300B but adds AM. 60 watts IHF, power bandwidth 6 Hz to 50 KHz, full-power frequency response 8 Hz to 40 KHz. AM and FM. $309
    • SR-600B – FM stereo receiver. 80 watts IHF, power bandwidth 6 Hz to 50 KHz, full-power frequency response 8 Hz to 40 KHz, harmonic distortion less than 1%, usable FM sensitivity of 1.95 uV. FM only (no AM). $369
    • SR-900B – FM stereo receiver. 100 watts IHF, power bandwidth 3 Hz to 75 KHz, full-power frequency response 5 Hz to 60 KHz, harmonic distortion less than 0.2%, usable FM sensitivity of 1.85 uV. FM only (no AM). $449
Other Harman Kardon solid state receiver guides:
  • Stratophonic (SR-300, SR-300B, SR-400, SR-400B, SR-600, SR-600B, SR-900, SR-900B)
  • Nocturne (Seven Twenty 720, Two Ten 210, Two Hundred 200, Five Twenty 520, Five Thirty 530, Two Thirty 230, Three Thirty 330, Eight Twenty 820)
  • 330 minimalist (330, 330A, 330B, 330C)
  • Twin Powered (430, 530, 630, 730, 930)
Harman Kardon SR600 receiver
Useful links:
Harman Kardon SR300B receiver
Identical to SR-400B except no AM radio.
1966 price $279
Specifications:
A. Amplifier​
Music power output at 4 ohms: 60 watts​
Full power bandwidth: 8-40 KC​
Harmonic distrotion 20-20 KC: less than 1.0%​
Frequency response +- 1 dB: 5-60 KC​
Damping factor: 25:1​
Square wave rise time: 5.0 us​
Hum and noise: 90 dB​
Input Sensitivity:​
Phono: 2.5 mV​
Aux: 200 mV​
Tone controls: +14 dB, -10 dB​
Speaker impedance: 4-16 ohms​
B. Tuner​
Useable sensitivity: 2.9 uV​
Image rejection better than: 45 dB​
Spurious response rejection better than: 60 dB​
Distortion better than: 0.5%​
Multiplex separation: 30 dB​
Antenna impedance: 300 ohms​
C. General​
Input receptacles:​
Magnetic phono: 2​
Auxilliary: 2​
Output receptacles:​
Tape out: 2​
Useful links:
Harman Kardon SR400B receiver
Identical to SR-300B except adds AM radio.
1966 price $309
"The newly-styled SR-400B gives you the convenience of upfront controls, tape monitor switch, headphone jack and easy-to-read tuning meter. Plus, a Harman Kardon exclusive, two-system speaker selector so you can enjoy stereo in one room or two - separately or simultaneously."
Specifications:
A. Amplifier
Input Sensitivity:
Phono: 2.5 mV
Aux: 200 mV
B. Tuner
C. General
Input receptacles:
Magnetic phono: 2
Auxilliary: 2
Output receptacles:
Tape out: 2​
D. SR400 only
AM sensitivity: 50 uV per meter
Selectivity: 10 KC bandwidth at 6 dB points
IF rejection: 55 dB​
Harman Kardon SR600B receiver
1966 price $369
Specifications:
A. Amplifier
Music power output at 4 ohms: 80 watts
Full power bandwidth: 6-50 KC
Harmonic distortion 20-20 KC: less than 1%
Frequency response +- 1 dB: 8-40 cps at full power
B. Tuner
Useable sensitivity: 1.95 uV
Harman Kardon SR900B receiver
1966 price $449.
Specifications:
A. Amplifier
Music power output at 4 ohms: 100 watts
Full power bandwidth: 5-60 KC
Harmonic distortion 20-20 KC: less than 0.2%
Frequency response +- 1 dB: 2-100 KC
Damping factor: 40:1
Square wave rise time: 2.5 us
Hum and noise: 95 dB
Input Sensitivity:
Phono: 2.5 mV
?? Tape head ??: 2.9 mV
Aux: 200 mV
B. Tuner
Useable sensitivity: 1.85 uV
Image rejection better than: 70 dB
Spurious response rejection better than: 85 dB
Frequency response: +- 0.5 dB
Distortion better than: 0.3%
Multiplex separation: 40 dB
C. General
Input receptacles:
Magnetic phono: 2
Tape head: 2
Ceramic phono: 2
Auxilliary: 2
Tape monitor: 2
Output receptacles:
Tape out: 2​
