I don't think experimenting with cables as EQ's will yield dramatic results. I made interconnects with Mogami cable for neutrality. My Crites B type similar to Cornwalls are more sensitive to placement. Getting the toe in right yields noticeable results. Room treatments and corner placement also critical. I have two amps I rotate in my system. First a restored Dynaco ST-70. Mids and highs are lush with good strong bass response. My SS amp is a restored Hafler DH-220 with Musical Concepts driver boards. With that amp the mids and highs are very close to the tube amp due to the MOSFET outputs, a very sweet sound. The bass response is tighter and has a bit more defined impact. Neither of these amps operate out of class A due to the 100db sensitivity of the speakers. A Cornwall 15" woofer with a ported enclosure isn't going to deliver perfectly tight and well defined bass but the right amp with good damping factor will help control that driver the best it can be. I would optimize my system bi-amping with tubes on top and the SS driving the woofers. I don't have an electronic crossover to effectively accomplish this but both amps do such a good job on their own I haven't bothered going that route.
Dial in your speaker placement, in the corners toed in and close to the front wall. Your Pass amp isn't ideal for these speakers. You also don't need flea watt tube power, just the right power. If solid state, consider a MOSFET based amp which will provide smooth high frequency response with your horns and tight bass. A restored Hafler 220 is a great amp that can be had with little investment. B&K, Adcom both also fet designs.
