At first it sounds like FM noise over a broadcast with a weak signal. But it sounds like the noise is happening or triggered by transients or impact sounds, like the attack of the note causing the trailing noise. It sounds different to me from the noise that toddalin describes. Also, what is the water sounds in the background? Is that in the recording?
Since you narrowed the source of the noise in the amp, anyone here can explain what in the amp will respond with ringing noise? My thought is something with high frequency damping in the circuit. Bad coupling or bypass caps?
