Thierry
Tape with a passion
Thierry thank you so much for posting the graphs.
Very enlightining to see the difference.
I never doubted that capactiors wear out especially after 35 years!!!
But seeing it is very educational
Thanks,
I think that apart from ageing leading to performance loss, capacitors are the electronic parts that have seen the biggest performance improvement during the past 15 years. Reliability, size reduction along with ESR (equivalent series resistance), leakage current, ripple current, all of these essential parameters have seen tremendous improvements, at least for respectable manufacturers like Vishay (Philips / BC Components, same group), Panasonic, Elna, Rifa, Nichicon etc..
First of all you don't need to replace ALL of the capacitors. You must first study the device schematics to determine which capacitors will bring a real improvement when replaced. Some are obvious, some are less obvious : by instance, a decoupling capacitor located in an area of the circuit may influence a remote part of it because of a feedback loop. Thus I would say that recapping shall be done with discernment. Of course if you have time (and money) you can replace all of the electrolytics and enjoy a nice result but personally I prefer to think first and act accordingly.
generally I don't touch any other capacitor other than electrolytic and tantalum ones. I may also use bypass film capacitors in selected areas but then whe are not speaking about restoration anymore, rather about modifications.
Hope it helps
Thierry
