Bpscorn
SO as people often seem to do, I've been given a HK3370 Receiver to look at/dispose of./ It has the common power on, immediately switch off/protect error so common with these, BUT for one small difference. The mute button prevents the board from going into protect or shorting out. I've issued the standard reset, and tested voltages when plugged in but on standby at outputs and all seems fine until the standby is switched on and *click* gone. Unless I hit mute. Its the mute factor that throws me
This leads me to believe (as a guess) it's possibly one of the transistors that prevents freeflow current going to speaker outs. but I could be very wrong. I'm so-so at soldering, and can DIY fix most problems but this one has me baffled even after looking at the schematics. Unlesss I'm missing some grounding screws somewhere...Could be the MCC I guess but I've also heard the capacitors were underarted for these....
Any thoughts or just sell for spares? Was hoping to use the power side amp but not the pre.
