topdownsound
I recently got a Klipsch RP-1400SW sub. Reading what I could about it, I found that Klipsch does not recommend plugging the sub into a surge protector.
This made absolutely no sense to me so I called them and found that:
1) This is a blanket statement, not a specific recommendation.
2) This is done to limit support questions.
3) The issue involves people hooking up some cheap piece of trash surge protector and when it fails, the sub won't power up. They call Klipsch, Klipsch tells them to plug it into the wall, and voila! Their sub is back working. So they just recommend people just plug them into the wall in the first place.
4) The support tech said that a good quality surge protector is never a bad idea and absolutely essential in areas of spotty power outages or older homes with window AC or other transients that can spike the power.
5) Just be sure that the total draw on the surge protector is less than the max draw of the stuff plugged into it. My sub can pull 1000w during an explosion on screen, but my surge protector can handle 1875w, so no problems.
6) The tech mentioned some surge protectors that I consider less than worthy. Stick to Belkin, APC, Eaton/Tripp Lite. I require a clamping voltage of 330V and over 3000 joules on my Type 3 SPD (receptacle devices). I'm less concerned about joules than I am clamping. I also have a whole house SPD Type 2 which only allows 600V in the first place as let-through. Stay away from the Type 3 that are 500V or 600V and read the tech specs for UL 1449, not some European or Chinese cert.
And as always, let's be careful out there.
This message for documentary purposes, in case someone is googling the topic. Just want to give back to this site for all it has helped me by helping the next person even if it is in a small way like surge protection.
