I recently got a pair of Dahlquist DQ-10s that hadn't been used in decades and decided to do a bit of refurbishing. I refoamed the subwoofers without trouble. Next, I was told to replace the blue 80 uF electrolytic cap (to the subwoofer) in the crossover. Got two 80 uF 100 V matching caps and replaced the old ones; now one sub sounds scratchy.
Photo album: https://imgur.com/a/CvBmWmd
I removed the old 80 uF capacitors from the crossover by cutting the leads (coming out of the capacitor)--I now realize I should have just desoldered from the joint. Even when the solder is hot, I cannot pull the old lead/wire out of the joint (see right joint in album).
I glued the new capacitor down and trimmed the leads from the capacitor to the appropriate length. I removed as much solder as I could from the previous joint using desoldering wick. I soldered the lead from the capacitor to the point where the old capacitor was connected.
Does the wire from the capacitor need to go through the joint or just make contact with the joint? Did I cut the leads from the capacitor too short? I see where the one joint (left joint) is supposed to connect, but the right joint connects to a wire on the underside of the crossover board.
Is this something I should continue to try to fix or bring into a shop? Can I cause permanent damage to the crossover through continued tampering?
What have I done to my speakers?! I fear I have gotten a bit ahead of myself with soldering.
