DT-500 malfunction.
69Z28Gary
AK Subscriber
I have a question for the Pioneer guys that mess with the digital timers. Most of my equipment has been sparingly used the past few decades. Life gets in the way sometimes. I have a DT-500 that seems to want to run fast. It's a switchable model between 50 and 60 hz. I moved the switch back and forth to see if there was anything there that might make that happen, and that didn't change anything. I was thinking DeoxIT D5 may work, I just haven't gotten any yet to see if that would do it. Anything else I can look at? Near as I can tell, after I reset the time, it runs as it should for about an hour give or take, and then it wants to run fast. I'm guess here but probably runs fast by a few minutes or more per hour. Not a lot, but I haven't sat and watched how much time it increases for an hour of run time. But, it does run fast until I reset it again. Anything I can do myself or is this a job for a tech? Thanks for looking. Gary.
After switching it between 50 and 60 hz, did you power the unit down and power it up to try again?
No I haven't, but now that I know, I will do that. Should it still be plugged in to do this or unplugged? I had it connected straight to a wall receptacle the last check I made a few days ago, but I read somewhere to plug into a surge protector, and make sure it's one that isolates the signal from the wall receptacle or something to that affect. I've had it in several different locations in my life, Texas, Georgia, and Delaware now, and it still did it. So I'm up for plugging into one of those protector units. I'll give a try now.
My DT-510 was doing similar things. Someone recommended removing the 50/60 hz switch if you live in a country that uses 60 hz (USA, for example). I did that and it corrected the problem for several months then the proble returned. There's a thread on jumping the MN6076. That solved my problem:
Nothing changed. I pressed the second's reset button and stayed there and if I'm reading it right against my cellphones world time it gains 10 to 11 seconds in a minutes time.
Something like that would make me quite nervous to do, so I'll leave that for someone that is confident enough to do it. Just need to find somebody now that can. Thanks for the link. Is my problem the same? I'm not sure. Probably better to hand it off to someone that understands it better than I. Plus, I've never soldered anything in my life, so there's that.
Have you attempted the DeoxIT yet?
If you haven’t, Deoxit your push button and selector switches as well as the 50/60 switch.
If you have a voltage selector switch, make sure it’s set at 120v if you’re in the US.
Not yet, I have to pick some up at the store. Not sure where to get it from though. Actually, the volt was set to 110, so I moved it to 120. I'll get the DeoxIT-D5 correct?
It didn't. It gains 11 seconds a minute. Approximately 20 minutes after resetting the seconds and the time current, it starts all over.
Too bad...how many seconds per minute was it when set on 110v? Try working those switches (50/60, 120v) back and forth a bunch of times to see if anything changes.
When you get the DeoxIT, spray those switches (50/60, 120v) and the front pots/switches if possible, then work them back and forth a bunch of times. Hopefully that does the trick.
BTW, you can buy DeoxIT online through Amazon, or head to any music instrument store such as Guitar Center (no affiliation).
I didn't count the minutes at first. I did a judgement call the first time noting around 15 minutes is lost per hour. Not accurate though. but close enough.
I folks. I did the DeoxIT to the DT-500 and still ended up with the same result, running too fast. Can someone recommend a shop that I can send this out to for repair? I'm not experienced and don't have ANY tools of that trade. Finding a shop where I live is fruitless. Any suggestions?
Why not post a WTB ad in BT for a DT-500, or one of the other similar DT-5xx timers? It will probably cost less than the repair bill.
I could I suppose, but I'd like to have the one I bought in 1979 fixed. Who knows if that one will do the same thing later.
True, but I've owned five DT-5xx timers at one time or another, sold three and still have two in service. None were ever serviced and I've never had any issues with any of them, they're pretty durable. Why so many? All were orphans, basically given away at garage sales. I just couldn't bear seeing them thrown in the dump.
I looked on BT here and didn't see any for sale. Ebay has two, but who knows what your getting there when they say untested. So I'll just have mine fixed, IF I can find someone to send it to. I'm getting ready to send off a CT-F1050 to either a shop in Rhode Island or a shop in North Georgia, so the timer will have to wait anyway. Yeah, I get ya. I'm a mechanic, USAF aircraft and many hotrods in the past 60 years or so, and just unloaded just about everything I have. So now I'm looking at my Silver Face Pioneer stuff for service and repair. I wish I could do it myself, I'd just make that worse.
I did find a few on Ebay. One was promising until I asked him to set the time to see what happens. He did, and the time started going faster on his, too.
