Dual 1019 No Sound Output
Ben Rothman
Hello all,
I'm currently in the process of restoring a Dual 1019 for a friend of mine. I have successfully gotten all the mechanical parts of the unit working flawlessly. All the automatic functions work exactly as intended. The only issue I have is that I am getting no sound output from the turntable. So far all I have done is switch the RCA cables with ones that I know work, use Deoxit on a Q-Tip to clean the contacts where the RCA cords go into, clean the head-shell contacts and even switch cartridges. If I turn the volume way up, I hear a little bit of sound. Any ideas on how to fix this would be great. I have worked on many Duals, but all of them just had the usual mechanical problems. I have never run into a dual that has electrical issues.
It's often the contact between the headshell and the arm.
Do the continuity test on all 4 contact pads. You might find issues there.
If you do buy a new headshell, get the Best Audio Parts one on eBay. It's the best option going including new and unused originals.
There is a mute function, two reed contacts underneath
check those
Hi sorry for the late response, I have been very busy. I already tried cleaning the mute switch with the deoxit and it didn't do anything at all. Do you have any other ideas of what I should do?
Get an ohmmeter and check from each pad in the arm to the muting switch. Do the same from the switch to the RCA plug. But, I've had Duals which tested ok though still didn't get a consistent signal UNTIL I changed the headshell sled to a Best Audio one. I also have several sleds and other Dual tables. Been There, Done That.
That will be my next step, thanks so much for the help.
