MKG
Elvish-mark’d abortive, rooting hog
Picked up a new to me Dual 1226 today. It’s been about 12 years since I’ve had turntables, and back then I was a wannabe dj so I was more interested in how well it could stay in the groove while I was abusing the hell out of a record. Anyhow, it came with a shure m91ed cart, looked pretty damn dirty so I took it off and hit it with some rubbing alcohol. I’m guessing that was a mistake because now it has a loud hum- the hum changes in volume if I touch the arm, platter, or any other metal bit.
I’m planning on opening it up and cleaning out the old grease and relubing everything (it holds a steady and appropriate speed, yay! But, automatic function doesn’t work- it just raises and lowers the tonearm and thinks it’s job is done), but first I’d like to figure out what’s causing the hum. Is the cartridge shot? Did I kill the stylus by cleaning it with alcohol? Is the ground wire not properly grounding?
Also, if I rotate the tonearm clockwise it comes up and out of its seat, is that normal?
