The cue control lever moves a 10" long lever underneath the table. The end of it under the tonearm engages the bottom of the tonearm lift pin. The other end (at the front, under the "Dual" logo) is engaged to the tonearm indexing adjustment. You will see that it is designed to slide on the mounting pin as you actuate the cue lever. It needs to slide freely. I have seen that mounting pin slightly bent restricting the movement. Make sure that is not bent and a small drop of oil will aid its movement. With this working properly, it won't slow down the speed of the lever release, but it will keep a slight amount of pressure on the lever and stop the flopping. As for the cue lever releasing on its own during the auto cycle? Not true on this model. Applies to the 1009(SK, SK-2, F F-1), 1015, 1019, 1210 through 1219, 1224 through 1229Q models only. To the best of my knowledge, no belt drive or direct drive Dual automatically releases the cue lever during auto cycling.
