Wayne,
The 1219 pictured is an early model. The height adjustment screw is hidden by the back of the arm. They had some issues with automatic stacking records and the cue. Not sure of the problem. Others here may know. Just finished fixing up an early 1219. I don't stacka records so the I don't have any problems with mine. It works really nice. As I have said, there are variations on 1219s. I have 4 1219s. Unit one is in my avatar. Has the German built wood base and cover. It's a later 1219. My second on is a later model. Don't need anymore but we went through the wars togather. This one is like yours. Broken arm, stuck speed selector, noisy motor stuck on off. I broke the height adjustment on it. Luckily I had a junk 1229. Has a US built wood base. Keeping it. Never had an early 1219. Keeping it too. Performance wise they are really good. The early 1219 works well. Wish you were here. Unit 4, another parts unit too good to junk. Has a broken speed selector. Greased it and set it on 33. Have a headshell coming for it. Everything works, it just needs the speed select lever. Will likely sell as is. Plays on 33 and everything else works. My local record store's owner like 1200 series Dual's. May barter for some records.
The 1219 for sale looks good. Too bad you can't try it. Once gone through like I did above, they run a long time. My 1219 pictured ran well for 4 yrs. I needed to oil the motor. Was surprised. End each day with that one. The bedroom system. Would be curious how much the one pictured would sell for. Good luck.
