I had a couple hundred hours on the Jantzen superior z caps. And prob over 1000 hrs on the alumen z caps. I did try the cast silver bypass cap up until recently. They sounded great in most aspects but added a dryness to the sound the took away something that I liked with the tinned copper, fast forward till yesterday and I replaced the tweeter cap again, but this time to z-cap ODAM. Very early so far but really like what I’m hearing so far. Better than the Alumn out of the box in my system. Also got around to rewiring with the Duelund tinned copper a month or two ago. A lot of people on the forums have talked about this as an upgrade. The wire I pulled out was very badly oxidized and very green. It was a pain in the butt but has made a substantial improvement. After seeing how the old wires look, I imagine any new wire would bring sonic benifits.For a beginner you've done great! How much time you giving the caps to burn in before trying something else?
I've never had the gumption to mess with my SC-IV's, but your posts are giving me some thought Beerad. May probe your knowledge at some point, so thanks for your insights!
That said I did an ARC sweep of my room a month back and found that my HRCC Center Speaker had no treble. Turned out the tweeter had been replaced with a stock Vifa D27TG-35-06 at some point in it's history (unbeknownst to me) and it was blown. So I replaced it with a ScanSpeak Discovery D2606/9220. Sounds awesome!
So, I guess to those who are afraid to tinker with what John had so maticulously built, there could be some improvements made, no doubt
Not a clue. I pulled 6 drivers out of my first pair of SC-V and none of them had numbers written on them like that. It could be something as simple as how they were cataloged into their computer records, or it could be something else entirely. I'd be curious to know.Anyone know what the numbers mean on DAL Speakers? I have a couple NOS tweeters (Vifa D27TG-35-06 variants) and they have 138 & 125 on them.
I'm thinking it's the 'Mechanical-Q' value, since these are spec-ed at ~1.22. Thoughts?
These are not like any I have seen and think they could be SC-III.A prototypes.
Yes indeed, X150.5 biased to XA30 Iq. with ZenMod Labs Iron Pre (balanced) which I built. I just love the Pass Labs DAL sound!I believe you could be right PWay... the SC-III.A's on Page 4 of this thread show a rounded top corner. Yours doesn't have that so they could be a proto-type.
I spy a Pass Labs X150 or X3/X5 in your rig. I run an X3 and love the sound!
Yeah, weird right? The other oddity is square corners. Leads me to believe prototype. We know Morels were on the shelf. Only thing I can say is they have every attribute of DAL. Flat response, although the high end is faster and extended. I've heard it said JD had Cantatas in his house. A stretch for sure, but could these be those? I possibly pissed off Carl M. after my last purchase, but I'm sure he might know...They must be prototypes, or something built with leftover parts, because I've never seen a DAL speaker with Morel drivers, except for the early SC-IVs that had Morel woofers. Those were changed about a year into production to Vifa woofers.
edit: From what I remember, the Morel MW 1076 is the same driver used in the early SC-IVs.
Yes, I used Jadem6 experience as a guide for my upgrade with good results.OK Folks, this information is probably pertinant enough that I thought we should preserve not only a provided link, but also a PDF of the text itself. It is a LONG read, but valuable for referencing what some have done maintaining and improving these 'legendary' speakers now approaching 30 years old.
@Beerad, the experience with my HRCC has convinced me that I'm going to mothball my SC-IV tweeters and replace them with the ScanSpeak Discovery D2606/9220. Then I will probably follow some of this advice. Have you seen this posting on Audiogon and what are your thoughts having gone through the upgrade? I saw you used Duelund wire for connecting things together.
Review: Dunlavy Audio Labs Dunlavy IVa crossover modification
Dunlavy crossover modifications starring Duelund Coherent Audio
This is the source for Duelund Components...
Yes I used jadem6 experience to help me navigate the crossover portion of my upgrade. He was very thorough in his process and descriptions. I have no experience with the scanspeak tweeter and how it will incorporate with the crossover. The seas crescendo which many have used is what I have opted for. I have tried different values of resistors in the main path due to the difference in sensitivity of the seas compared to the original. I settled using the same value that was in my original crossover. Sounded the best and most natural.OK Folks, this information is probably pertinant enough that I thought we should preserve not only a provided link, but also a PDF of the text itself. It is a LONG read, but valuable for referencing what some have done maintaining and improving these 'legendary' speakers now approaching 30 years old.
Yeah, those are beautiful and I'm sure sound just as nice! Great setup there! Look like they have just the right amount of separation and rear wall clearence!I always admired John Dunlavy's magnum opus - the classic Duntech Sovereigns...
Yes the Sovereigns are sizeable. They're the same height as the Infinity IRS-V's. My friend built a dedicated Den in his backyard for that system, hence everything was optimised for those speakers. Their transparency isn´t quite up to the level of the best modern speakers, but that can be substantially improved with a high end x-over upgrade incl: better internal wiring + some nice WBT Nextgen binding posts. That was a grainy photo and didn't really do the speakers justice. I've seen higher res photos and those sepakers were in beautiful condition. The buyer got a good deal.Yeah, those are beautiful and I'm sure sound just as nice! Great setup there! Look like they have just the right amount of separation and rear wall clearence!
I wish I had the room to get a little more separation for my SC-IV's, but we have what we have! And that goes back to some comments that I've made in other threads that your room dictates your sound in many cases, even though there is always room to make minor tweeks.
