No problem as far as I can see. The Yellow Sheet mod has been discussed, and discussed on AK; with many weighing in that it’s not necessary at all. My point had more to do with which diodes to use and whether to double them up, then whether to pay $25 or $50 or $100 or more for the tube, or…………..but you did fix what was not broke , im just going to run the tube with no yellow sheet , no added diodes , just like dynaco does in original form , how is this over thinking
I’m not sure the quality of rectifier tubes is up to the old Mullards or whatever and then with higher line voltage there could be a problem. I use a bucking transformer and have had good luck with the basic Sovtek 5AR4 but then, I might be overthinking it.
