does the improve the mid range or the whole response ? or the bass ?Fwiw, I also recommend replacing the two 1.5 meg 1/4 W resistors on the board with 1.2 meg 1/4 W to give the splitter triode a bit more linear margin.
So because pin 6 is a empty nothing on the socket , this mod just adds a 100 ohm to that transformer lead ? a lead that all ready must have lots of resistance from the transformer windings , im still considering it , but just trying to understand itThey are 100 ohm 1/4 watt.
Disconnect the 1k 1/4 watt resistors between tabs 5 and 6 from tabs 6 and connect the now free ends directly to the board with wire extensions. Move the output transformer tap leads from tabs 4 to tabs 6 and connect the 100 ohm 1/watt resistors between them.
Move the feedback wires from the board from tabs 4 to tabs 6.
It moves the average splitter triode bias to a more favorable voltage distribution center, 25%-50%-25%.I don't think you want to change those 1.5M. They feed the screen voltage to the pentode voltage amp.
At the worst, it's cheap enough insurance for the A-470 OPTs. At the best, it's cheap insurance for the A-470 OPTs. Dave G has discussed it in the thread and elsewhere. Marantz used them.They are "stopper" resistors like grid stoppers. They can provide a filtering effect to inhibit the formation of parasitic oscillations on the screen. Don't know that Dynaco ever issued a recommendation for the those for the ST70. Other output tubes have recommendations for them on their sheets. ....Never had a problem in my amp without them. Perhaps there is an issue I'm not aware of. Would like to see a quote for it.
Also discussed in the base line thread. Variability of individual Tubes & subs will move it around, which is why I said "average". It's not absolutely necessary, but it does reduce stress on the splitter cathode/heater by reducing the voltage differential between them. A main cause of driver tubes becoming noisy in these amps is heater/cathode leakage.Read the manual for test point voltages on the 7199. The voltages on pins 1,2,3,8,9 are non specified and as the manual says can be all over the place for any subject tube in place. Simply changing the 1.5M resistor won't guarantee any result in improvement. I believe the ST70 addressed the issue of inverter balance by sending some FB back in from the screen tap of the non-inverted side of the OPT.
It's @dcgillespi that delves into the revised ideal splitter ratio distribution later in the thread, had earlier used a different approach. He also discusses the input DC coupling vs stability with the FB earlier re adding a blocking cap.Pio, I'm lookin' hard for the material I have where Hafler explains how the inverter imbalance is compensated for. He explains the reason, cathode degenerative FB that exists because of the non-bypassed nature of the that cathode, and the solution. It's good info that can be employed in other circuits. ...digging..
The blocking caps (The only caps in each phase of the signal chain of the oem '70) effectively isolate the output tube G1 bias from the splitter voltage distribution, so that's unrelated to the linearity of the splitter operation and the output bias.The output tubes have no reference to the DCV on the plates or cathodes because they are isolated from that voltage by the coupling caps. The idea of having a load balance is to keep the signal (+)/(-) from clipping or going into cutoff out of sync. If the drive signal is smaller that the voltage range then there won't be any problem even if the original 33% division kept. If you are going to drive the outputs with a larger signal than the amp was designed for then yes you have to expand the range, but is that the case, that the drivers are being asked or made to push the inverter harder, passing a larger signal than can fit the 33% voltage range and so get clipped? The problem is in using the voltages read on the tube that may or may not be expressing any practical diagnostic value. And just expanding the plate/cathode differential without need isn't going to give the output grids matched inputs from the inverter.
I have two Mullard builds with A-470 clone OPTs I'm very happy with, the oem Dyna 70 refurb was an excersize to address compromises to get the most from the Laurent/ Tucker topology with the Dyna A-470s, of which it is capable, with modern passive parts and tubes.Unfortunately I'm just one voice fighting the ignorant tide of lemmings, with my philosophy that iconic pieces of history should be revered and kept whole. If someone wants to clone a design and mod an amp for the fun and sake of curiosity, I have no problem with that. But history in hand, take a piece of history and rebuild it as is with modern high quality parts to extend its life for the future, but don't create a different animal that breaks the chain of knowledge and respect of those who worked to create a better life for those of their time. Lemmings don't know they are lemmings until they are in freefall.
