Bradbrews
Time for some measurements:
First off I decided to drop the line voltage down lower. Running 116 v now, vs more like 121v last night.
Then I recalled having this test socket to measure the tube voltage between pins 3 and 8. I also put the watt meter on the amp. Later I’ll check the cooler running one.
Then, after some math I decided to drop the current from 67 mA to 50mA. That lowered the power draw from the wall 19 watts.
I’ll see what difference all this makes.
I suppose I could run even less power through the tubes.
What are you guys running 6550’s at?
