Dynaco MkIII restoration - join the ride
I polished up the can caps and they can be slipped into the slots for show. But I decided to leave them out to keep the hole open for additional ventilation from under the chassis without having to break out the drill (not an option). Also, since the caps are in the "back", at least the way I have them on the shelf with the power switch and connections facing forward, and running the cages in place (but not screwed down so special guests can see them naked) you would not see the cans anyway. They are very quiet, slight hum from the amps, I don't hear any hum through the speakers until about 3/4 volume with no input, using a McIntosh C33 preamp. Regarding sound, I like them very much, I don't have experience comparing dozens of amps to each other, but did compare these head-to-head with my everyday MC-2155 (150wpc solid state) McIntosh power amp. The Dyna's had a presence and "real" sound that the Mac clearly does not (at least in comparison). Tried through Klipsch Heresey II's and 14" 2-way JBLs, with similar results. Not sure if this is a fair fight (tube vs. ss), but I would give the first round to the Dyna's And yes, the Mac is up to snuff, with relatively recent full recap and then additional check out and work done by Audio Classics. That said, I have only put a few hours on the Dyna's so still listening and learning what goodies these ~60 year olds have to give. At this point I am very happy with the "stock" sound, and not inclined to modify them further for the foreseeable future.
The Dyna tube amps have a very simple self-compensating signal path with but one capacitor in the signal path of each phase, it's simply elegant design.
The Dyna tube amps have a very simple self'compensating signal path with but one capacitor in the signal path of each phase, it's simply elegant design.
Pio, thanks for your helpful and encouraging posts during this project. Overall, I'm very happy with the result. Now on to getting the PAS3x I got at the same time working. It's been messed with and needs work. Will get a similar treatment, upgrade the PS and put in new components, but all stock values. Not going to mod it. If I don't like it, I will upgrade to something else, but the Mk IIIs are not going anywhere.
I ran diagnostics on these using Analog Discovery2 and software from "The stuff made". See attached for THD+N, vs. Frequency, THD+N vs. Power, and Frequency Response curves for both amps after completion of restoration.Dynaco MkIIIs Frequency Response.png Dynaco MkIIIs THD+N vs. Frequency.png
Well done! I am in the middle of a similar resto, I am just looking for a second chassis have everything else including the new power supply boards stuffed. Have the bells off to send them to be powder coated, but may be a month or so. Yours has me getting excited!
