What is everyone's thought on this particular amplifier.
I have found one that looks to be in great shape.
What would one expect to pay for this particular amplifier?
It's a really nice integrated tubeamp. As such it has all you would expect, even a decent riaa stage.
The power stage is close to identical with st-35 only other driver tubes (7199) to compensate for the
tonecontrols. Thise tubes usually is ok, if they need replacements i think it's better to use
ecf80 with adapters alternativly get new boards that is redesigned to use ecf80/82/6u8 one source
is
http://tronola.com/html/daves_store.html
The amp runs hot, and it is hard on the power tubes ( el84). They must be replaced as a matched quad
( actually no big thing many suppliers sell them for reasonable money).
If the can caps get bad, one alternative is to install an EFB board that replaces the can caps AND
will make the bias adaptive, and it also lessens the load on the tubes. Also found at daves store.
The amp has hum-control pots. If they don't work it might be the 7199 that has developed
filament <> cathode leakage.
