Anti_Skate
Well-Known Member
I am envious!
Me too.
I would love to find an un-built kit. Dynaco, Heathkit, Eico, etc.
I am envious!
Ye
Measure the resistors before mounting then, too, to be sure they've not drifted as well. Use fresh solder, too.
Enjoy!
Cheers,
David
This cheap power supply seems to work well for this. You can limit current, and I have it set to 100ma. Of course the resistor limits current, but it's a nice feature.Agree.....This is what the Caps look like inside:Yep, that's a time capsule! At least it is going to someone who would appreciate it - nice! If you're planning to construct it, by all means document it if you have the time and inclination.
I'd suggest, however, that you plan on replacing the electrolytic caps. They're at least 40 years old and will have likely dried out inside in that time. Measure the resistors before mounting then, too, to be sure they've not drifted as well. Use fresh solder, too.
Enjoy!
Cheers,
David
I have one of those MCS tv/monitor/scope watt meter. The one I found had NASA calibration stickers with dates on it along with a sticker with "launch pad 6" on it. used as a closed curcuit monitor for the launch pad I guess. I want to recap it and make what ever adjustments needed but cant find a repair manual.
Is It normal for the screen to roll up or down when in scope mode? I cant get mine to stay stable and not roll.I bought mine new and think I have the owners manual but that probably would not help.
I think Larry Klein of Stereo Review had one that was in the background of the photo for his column.
Yup, thanks.It seems to roll if you don't cherry-pick an appropriate frequency. No frequency scaling. Maybe that's what you mean?
