The Dynaco ST-70 was designed in an age when high accuracy sound reproduction was THE ONLY goal in high quality, high fidelity sound equipment, and came to the party with an impressive list of credentials to backup just how well it could accomplish that. As originally designed, with:
1. A frequency response from 20 Hz to 20 kHz that is flat within .25 db,
2. A power response that will allow full reproduction of the 20 HZ to 20 kHz bandwidth within 1 db of rated power with credibly low distortion,
3. Ample power to handle virtually any speaker of the day with virtually any source material of the day with ease,
4. Excellent HF stability,
5. Excellent transient response,
6. A very good Damping Factor,
7. Relative insensitivity to fluctuations in load, and
8. Credible performance with both channels driven,
the ST-70 delivered a ton of performance for very little money, from a young upstart company that had no business producing such a good product -- all of which made the big boys blink, and set standards that many amplifiers manufactured today could only dream about achieving.
The biggest failing this amplifier has, is that it was too good for the price. As a result, there were more sold than by any other product of any other manufacturer -- by quite a large margin -- which is to say then, that it became all too commonplace. Once that happened, then just like the equivalent of the small block Chevy that it is, everybody and their brother's uncle started producing modifications to make it "better" at what it's supposed to do.
What's interesting though is that those producing the modifications say it is to address the 70's rather "average" performance, diminished top end, or weak bass presentation. Some claim the driver stage is "ineffective", and so on, while they all say that their modification turns the ST-70 into the best amplifier they've ever heard -- but offering precious little evidence to backup their claims that its performance is actually any "better".
Truth is, many people today have little understanding for just how good the original design really is. With many having little concern for specifications -- or accuracy for that matter --their ears then become the sole judge, trial, and jury of all things audio in the creation of good sound.
But the ST-70 wasn't designed to "create" anything at all. If it did, that would mean it was altering the original source in some way. In fact, ST-70 was designed to create as little as possible on its own, while faithfully REcreating as much of the input signal as possible, and no more. THAT is the standard by which the original design should be judged.
Likely then, those who feel that a properly operating ST-70 alters or hinders sound may not really be familiar with what truly accurate sound is at all, but rather, have their own definition of it. However, with nothing to base their definition on, it becomes a slippery slope when measured data is disregarded, and accuracy becomes solely based on perceived sonic performance -- if accuracy is to matter at all. Against this, the proven performance capabilities of the original design, and the unmatched sales record of the ST-70 provides overwhelming evidence for just how well it did in fact accomplish its goals.
That being said however, there are simple things that can help adapt the ST-70's original purpose to today's audio reality:
1. The rectifier tube can be replaced as discussed for more efficient, and cooler operation, and eliminates the exorbitant cost of NOS and less dependable modern replacement tubes.
2. The line voltage should be adjusted as necessary to maintain the original goal of high performance, coupled with very conservative operation.
3. As discussed, an input coupling cap should be installed as necessary to prevent the possibility of any dc component within the signal source from upsetting LF stability.
4. Choose your 7199s carefully. I have found that those employing a carbonized coating on the side of the glass envelope containing the pentode section to be quite consistent in delivering proper performance.
Beyond these measures then, any modifications changing the active circuitry to alternate designs will likely change performance capability, both measured, and perceived. That may be your goal which is fine, but if not, realize the possibility exists.
As for those interested in installing EFB(tm) in the ST-70, it can be done, and will result in reduced distortion and quiescent operating currents. But because of how well the ST-70 was originally designed, the gains it will produce will be greatly limited, as compared to other installations documented, making the return on the effort rather small.
In addition to providing EFB action for distortion reduction, previous efforts have also allowed EFB to correct for inappropriate bias configurations used for the loading conditions offered, reduced output tube dissipation levels that were operating at or very near maximum ratings, or even change operating conditions that were inappropriate for the load conditions offered. With multiple benefits then, adding EFB to those scenarios is highly recommended.
But as the original design of a unit becomes optimized from the get-go, adding EFB produces ever diminishing returns -- as it should. A properly designed amplifier operating from regulated power supplies would not benefit from EFB at all. EFB is simply a way to achieve virtually all of what regulated power supply operation has to offer with regards to distortion reduction, with the possibility of correcting other ills along the way as necessary.
In the ST-70, EFB would not add extended tube life to speak of, as the operation of the output tubes is already quite conservative to begin with. It cannot be used to correct for original design ills in the output stage, because they basically don't exist. It can reduce distortion some, and heat dissipation some, but the distortion levels of the original design -- even with both channels driven -- is still quite low, and low enough to suggest that EFB would not really provide any sonic improvement to speak of. That leaves reducing heat dissipation levels, which would be reduced more by eliminating the rectifier tube.
I'm hardly trying to trash my own product! But in this case, the ST-70 was so well designed as to benefit only marginally from the concept.
Those new to an ST-70 then owe it to themselves to first properly restore it to its original configuration, and then listen to it carefully for an extended period of time. Then, if you are looking for a different kind of sound, so be it. But at least find out what caused it to outsell everything else by such a remarkable amount to begin with!
Dave
