Hi Atmas -- The cathode coupled NFB trick was used by AR of course, and also Ike Eisenson of the old Audio Dimensions days on the ST-70. While it doesn't provide a lot of feedback (about a 1.5 times reduction on each side of the push-pull connection), it is more effective than it looks on paper, in that the effective feedback is equal to the square of the feedback factor.
The down side of the approach however, is that with it, significant driver distortion can enter the picture, since the output stage now requires about 100 volts peak to peak to develop full power output. Still, if this is accounted for, then good results can be achieved -- although by itself, it is usually not enough feedback to lower the internal impedance of the output stage to the point where it can be a non-issue.
Thanks for contributing your experience!
Dave
Dave
