jsg1469
Member
My 1962 stereo 70 is all original with the exception of recently replacing the circuit board (stayed with original 7199 circuit) the selenium rectifier to a 1N4007 and the two bias filter caps to 100uF 100v. My right bias pot is loose and not stable. My meter is all over the place if I touch it. I tried cleaning but didn't work. Replacing both 10k pots today. I read Bob Latino recommended changing the 10k resistors on the bias bar to 5.1 but cannot find the thread. Question: all I have available is 4.7, 6.8k and 10k resistors at 1 watt. What will replacing to a 4.7 or 6.8k do to bias settings? Should I just test and keep the 10k or replace with 10k if necessary? I only use EL34 and occasionally KT77 in the amp. Thank you
