Wow, thats a mess underneath.
lets see if we can work through it a bit here.
Tube rectifier is gone, and it looks like a cap lives in that space. Don't hate this, the 5AR4 is a trouble spot. The choke lives on top, don't love that but functionally it doesn't matter a ton.
The grey caps bottom side on the top left corner live where the choke originally lived, so thats why that is up top now.
The old rectifier has been replaced with a single section cap. I can't quite tell if the quad cap is still in use. It looks like at least one section is open. I see resistors on it but not sure if any wiring actually goes there. I'm sort of curious if it was abandoned in place and subbed with the cap in the rectifier spot, the two grey ones in the top left, and the light blue cap.
orange caps upper right corner is the bias supply stuff. This appears basically stock, just with new caps. Likely no problem here.
I'm assuming the bias rectifier has been replaced but I don't see it. I do not see the old selenium though. No issue there either.
The 1/4" jack on the front appears to be for checking the bias. Functionally this works, I'm not a fan though. As I mentioned earlier I'd change this out for pin jacks and probably add a grounded pin jack somewhere to make the whole process cleaner and easier.
RCA jacks are the RCA jacks.
Looks like all of the transformer leads have been clipped back and spliced to new wire. I don't hate the idea but its all white wires which makes tracing a lot more difficult. If you wanted to build a bomb nobody can disarm this is a great tactic, if you want something thats not a pain in the ass to work on, this isn't the way to get there.
If this were mine, I'd leave it solid state rectified with an appropriate resistor to drop the voltage and revert the power supply to an otherwise stock config. New quad cap, wire all that up as it was meant to be. Put the choke back downstairs in the original location. I'd probably put the rectifier socket back, and do the diodes and resistor there as a plug-in, but allow the option of running a tube rectifier if anyone ever wanted to.
