Dynaco st-70 hookup
ok well that answers that much at least. I'm guessing at least one more section of that quad cap has to be in use, the 6.8K resistor looks like its coming from the terminal closest to the rear panel.
Looking closer at the grey caps, they appear to be wired in series. 800uf @ 330v makes 400uF @ 660v, so thats "one" capacitor.
So thats what, 6 capacitors in the HV supply? 3 in the quad cap, one from the grey ones, one where the rectifier lived, and that blue one. And a choke somewhere in the mix.
I can't actually find the HV rectifiers here. I'm guessing maybe they are on the terminal strip where those orange caps are but not sure. Can't see any other logical place for them to live though, and the orange caps as diode snubbers make sense.
Found the bias rectifier, its on the terminal strip with the rest of the bias supply.
Honestly, TRS for biasing two tubes with one jack is kind of a cool idea. Not really intuitive so I wouldn't install it on someone else's amp, but for personal use with a custom cable it's a clean solution, especially if you've only got one chassis hole to work with. Better than drilling another unnecessary hole IMO.
Edit: in this case biasing two pairs of tubes, since ST-70 has a common cathode resistor
It's a bad idea to use a "headphone jack" for anything other than headphones.
Labeled pin jacks are a better idea.
The Knight KB-85 used a pair of 1/4" jacks as bias test points.
They're the same as using test jacks to measure across the 10 ohm resistor. There's no make-or-break function here, like there was in the old Heathkit amps.
I was just pointing out that it’s certainly not a new thing, not commenting on this particular application of it.
So I’m not quite sure what type of cable I need. 1/4” jack to what? Where do I adjust the bias now?
Unfortunately, that's the problem. It's a very obscure way to meaure the bias. Short of making your own cable, you'd have to get one of these:
and one of these:
Plug the adapter plug into the jack on the Dynaco. Then plug the banana cable into that, and use the banana plugs with a digital multimeter to measure the DC voltage across the 10 ohm resistor in the maps.
Or get one of these:
IMO the easiest solution would be to replace that headphone socket with three banana female connectors. One black in the centre, a red on each side. Multimeter probes can directly connect to them.
Regards,View attachment 3623564
IMO these would be better for banana jacks. https://www.digikey.com/short/7rdqz0pj They come in many colors.
Alternately "pin" jacks that you can directly slip meter probes into. (Smaller hole than the banana jacks) https://www.digikey.com/short/df8bwqc5 Also come in many colors.
I absolutely agree that adding normal test jacks would be the best solution. I just don't know what the OPs skill level is. If (s)he's not in a position to drill the chassis and rewire the amp, then some other solution has to be found.
Yes we have lots of suggestions and ideas but we do not know what skills @canuck13 has or what he or she wants to do.
What say you @canuck13?
What is your skill level? Handy with a soldering iron, etc.
Do you just want to check & set bias as is?
Do you want to make any changes to make bias setting easier?
Do you want to really make major changes to the amp to bring it back more towards the stock set-up.
I'd go with this ....
Choose ST-70 (C)
View attachment 3623599View attachment 3623600
That would be a good choice if the OP wanted to move the input jacks back to the stock location.
I'm a fan of the pin jacks. Simple to make a panel with a couple of holes to fit into the stock RCA jack location. Not sure 3 are going in there though. Might get them in the space, but the "flare" on a lot of meter probes would make using them packed that close together difficult. Could do the two test points in the RCA jack location and the ground where the stereo/mono switch lived though.
bias/balance kit is an option but would require re-locating the RCA jacks. its a better mousetrap than the stock system. Big downside is the amp looks stock again, and I've always thought those octal sockets on the front were something of an eye sore. Thats just my aesthetic opinion of course and has no functional impact.
still none of this sorts out what the heck is really going on here. I'd still prefer to know exactly whats happening electrically, and quite likely un-do it so it doesn't look like such a mess. I don't like working in balls of spaghetti. Too many years dealing with industrial controls, a proper cabinet has a lot of neat wiring that is easy to trace. Bad cabinets are a complete nightmare to work in.
Thanks for all the replies everyone. Much appreciated. I do have skills to rewire, solder, drill ect but I don’t quite have the depth of knowledge on system. After hearing all your feedback I’m leaning towards getting the original schematics and wiring it back to its original state. I guess I will have to make the one decision on wether I should keep the rectifier SS or not. I imagine it will affect the final results sonically ?
Endless arguments on that, I just don't want to feed them expensive rectifier tubes.
Agree with @gadget73. Not a guitar amp where B+ sag adds to the "tone". I like SS for my amps. Lots of arguments either way.
You can always wire it for a tube and use a plug-in SS rectifier. That way you can choose what works for you. Either way look up the ST-70 yellow sheet mod.
I prefer SS rectifiers as well. I only have three amps with tube rectifiers at the moment. I've been meaning to put a SS rectifier in my ST-70. The other two amps with tube rectifiers are single ended. The Copertop WZ34, or WZ68 SS rectifier will give you the 17v drop of the 5AR4. I'm using the WZ68 in a pair of mono blocks.
