Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I'd like to keep it as stock as possible. Can anyone suggest a similar replacement power switch for a st70? I'm trying to complete orders at both digikey and mouser.
You can get a suitable replacement Dynaco ST-70 power slide switch at any Radio Shack. It is Radio Shack part number 275-401. This switch will work and fit the opening perfectly. The only minor glitch is that the Radio Shack switch is not threaded like the original Dynaco slide switch. It's not really a problem though. All you have to do is place two 4-40 nuts on the other end of the two screws that hold the switch on. Link is below ...
