Dynaco ST70 Distortion.
First I would like to thank those of you that responded! This was one of those things where you know something should work but it doesn't. Well I purchased my input board blank and stuffed it myself. I decided to check the components to make sure the right values were installed, and then I noticed it. I never installed the 47K resistor on the left or right side located in front of the 7199 socket. I just soldered it in and the amp works great. Thanks again guys!
EXCELLENT!!!!!!!!!! Good work now enjoy
that'll do it. Thats the cathode resistor for the phase inverter, and it will not function without it. unless its the plate resistor, in which case it will still not operate without it.
I struggled with mine due to careless mistakes but with the new Dynakit 7199 board, etc you should be able to enjoy it for many years. Just enjoy it.
