I have a set of Edcors in a not-quite Z565 clone. Mine are 40% UL taps, but they offer a 23% now. Maybe a bad assumption, but I'd think they are essentially the same as mine, just with the tap points moved.
If thats the case, based on my results vs Dave's results using them on otherwise identical Magnavox 9300 builds, I can say the HF response is not identical. With some tuning I'm it can be worked out but I wouldn't expect to plunk an Edcor into a design perfectly tuned for the Dyna iron and expect it to be identical. I'm not using the UL taps either, its possible putting them in use changes things slightly.
