I was thinking of a populated board ( or a board with brand new components )Heh. Not quite 'burning' money yet. Replacing the coupling caps however might be considered a bit steep. Good point though on the board. After replacing the resistors and if no luck, swapping transformers, the board will be on the list. At least I can move my nice new parts to a new board.![]()
Have you not tried replacing the coupling caps already?
So have you try the reverse? Use a heat gun and gently heat the components to find the offending one.
Easy; first heat the whole board, then spray coolingspray on one component.I have not... although that is a good idea! Just have to figure out how to isolate the heat enough so it isn't spilling over all the components.
An old fault-finding technique
I'm sure you have tried this, but if not, first thing to do is pull out all the tubes and use caig deoxit on all the tube sockets.
I'd buy a new board from dynakitpart, a populated board. Then move the tubes and listen to the music.
